Configures a log target to receive only those events that meet the specified match criteria.
| upm_profile_name | Specifies the UPM log target to be configured. |
| any | Matches any event. Use this option to remove a limitation configured with the regex option. |
| regex | Specifies an expression that must be contained in all forwarded events. |
N/A.
This command further restricts the events selected by the command: configure log target upm {upm_profile_name} filter filter-name {severity [[severity] {only}]}.
The following example configures UPM log target testprofile1 to receive events that meet the criteria contain the text warning:
configure log target upm testprofile1 match warning
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the Universal Port feature, see the Switch Engine v33.1.1 Licensing Guide document.
